I have a motor, lincoln 30 hp, 1.25sf wired for 460v nominal. fla 39 its hooked to an hydraulic pump on a test bench. when it is in use system pressure at 7200psi, it draws 39-40 amps. the exact same motor and pump on another bench draws 10 amps less. The motor has just been rewound and new bearings the pump also has a fresh rebuild on it, no change in amperage. on thermal image camera it showed a hotter phase on one leg, but that was before rebuild havent had a chance to retake more images probably this week.
we are out of ideas, so im throwing it out there to see what you guys think.
clayton
clayton
