I am in need of some expert advice on a motor sizing question. I am trying to replace a 2HP 3 phase motor on a meat cutting band saw with an equivalent Single Phase motor. I've done a bit of research on the subject and there seems to be conflicting opinions.
On one hand sources have suggested that I would need to increase the Single phase Horsepower from 30% to 50% in order to do the same job the 3 phase motor does.
On the other hand my motor supply house tech support tells me 2HP is 2 HP no matter if it's a 3 phase or single phase. The only caveat he mentioned is that the 3 phase motor would have an advantage in applications where high starting torque is required, and the band saw does not start under load.
So who is right?
Any input would be greatly appreciated.
Thanks
So who is right?
Thanks
