I am trying to interpret Table 430-22(b) and have several questions.
1. Does this table apply to sizing a mixed service (motors, heaters, lighting) and the feeder?
2. In the table is the "Minute Rating" the manufacturers rating on the motor or is it the maximum operating time of the motor in the application?
3. If I have a continuous rated motor in an application that is limited to less than 15 minutes operating time do I use 125% of the full load current (as per 430-22(a)) or 140% (as per the table)?
4. This is the silly question (assuming the others are not), if the answer to 3. above is 140% then why is the percetage higher than for continuous duty? Wouldn't there be more heating in the continuous duty situation?
Thanks in advance
C
One additional question: if I have a 5 Hp motor that only runs for a max of 3 seconds at at time and approx 5 minutes rest afterward, do I need to include this motor in the load calc? (Please explain why or why not)
Thanks in advance
C
