- Tennessee NEC:2017
- Semi-Retired Electrician
I had a customer bring me a motor to see if I could wire/connect it to run on 120V. There is no visible wiring diagram but the nameplate shows 110V/220V, so I know it can be wired for either. There are 6 leads, 4 are labeled T-1 thru T-4, and 2 are unlabeled. I'm guessing the 2 unlabeled are the inputs, and if so, I don't know which would be neutral if wiring for 120V. I presume I could use a meter to check continuity but I don't know what I'm looking for.
I need to know two things...........
1) how to wire it
2) can it be wired forward or reverse
Here are some pics. If you can't see the name plate, it says
frame 1200
H.P. 3/4
type KB
volts 110/220
cycles 60
phase 1
amps 9.8/4.9
temporary image hosting
1) how to wire it
frame 1200
H.P. 3/4
type KB
volts 110/220
cycles 60
phase 1
amps 9.8/4.9
