emiller233
- pittsburgh, pa
Need advice on motor temperatures/problems. Commissioning a machine and I noticed the motor is getting hot! It is on a water pump for recirculating water thru a heat exchanger. So no real load to speak of on it.
Been running the motor for about 45 minutes – 1 hour and the motor is getting pretty hot, hotter than the pump in fact. I checked all the obvious things like wiring, amp draw etc. and everything is fine. It’s pulling about 5 – 5.5 amps with an FLA of 6.5 amps and SFA of 7.46. The fluid temp is only about 90 degrees and there’s been no load to speak of on the motor.
You can see from the pictures below that the rear of the motor is significantly hotter than the front of the motor, which seems to point to a bad bearing. There are no greese fittings either.
Any ideas???
Any ideas???
