We have a 480 volt 40 hp 49.5flc motor driving a large blend tank. The motor is controlled by a VFD which is usually set around 10hz. The motor has been running at full load amps at the low frequency and often over amps and trips the drive out. I believe the blend tank load is simply too much for the motor, however I would like to know how the motor reacts to low frequency. My question is; does the motor rated hp decrease along with the decrease in frequency? Does the torque produced change with frequency? There is also about 150 feet distance between motor and drive cabinet. Would a load side reactor help? Any information is very much appreciated!
