Motor JBs
noveds
New member
Ingleside, TX
I have around 300 motor JBs on a construction project that may or may not require reducers to accept the designated cable glands. I've measured everyone of them and some of the time I get a measurement that Crouse Hinds doesn't make, the only accepted vendor. I've used calipers and a ruler with the same result. For example, 4.5 inch to 3 inch. Crouse Hinds only makes a 4 to 3 inch for my application.
It's a simple problem that has me frustrated and is going to make me look very bad when I order 100 wrong reducers. Any help is greatly appreciated.
I'm guessing you mean threaded bushings. A 4" rigid or IMC will measure 4.5" outside, so that's about what you should see in your measurement.
