I became a J-man at a steel mill. Motors up to and including 10HP we used ring tongues and stove bolts (courser thread than machine screws, square nuts). Larger all got Kearneys (split bolts). If you used a wire nut on anything (and got caught), you could lose your job.
Varnished cambric went over the connection, then a layer of at least 5 wraps of 3M #130 rubber tape, finished with 3 wraps of 3M #33+ vinyl tape. we all carried all 3 hanging on the tape chain of our tool belts at all times.
As it was taught to me, the varnished cambric was so the NEXT GUY didn't cuss you out, because it wouldn't stick to the connection, even after years of heat and oil etc. The rubber tape was for protection against vibration of the connection against the side wall of the peckerhead. The black vinyl tape protected the rubber tape from coming unraveled before it could fuse. Some guys from other jobs came in with doing the "sticky side out" routine on the rubber tape, they were told to change. The reasoning I heard given was that over time and heat, the rubber is designed to fuse into a solid mass, the glue was only there for the initial install. So without the cambric it would still be difficult to remove. This may have been somewhat unique to us being a steel mill where more heat was always present. Later when I did a lot more pump work, I began using the sticky-side-out routine and no cambric (I went to a supply house and asked for some once, got a blank stare), never experienced a problem.
