wlancaster
- greenville, sc
- Building Inspector
Hello, trying to get some help on a question from the nec exam I failed this past monday. I don't remember the exact numbers but it was close to this:
5hp squirrel cage motor, 3phase, 208V. Calculate the branch circuit conductor size, use THHN wire.
my questions are should I assume 115% of the FLC since no info is given(nothing said about the duty of the motor), and since the answer will be less than 100A, I must use the 60 deg C column on the ampacity table, even though the questions says use THHN wire. right??
Thanks for your help!
