tgifredday
The NEC requires that equipment have markings that specify the temperature class or operating temperature at a 40 deg C ambient temperature, or at the higher designed ambient temperature. Are motors considered equipment in the NEC? Motors are not called out in the definition of equipment, but it could be considered equipment based on the definition. The motor section in NEC 501.125 does not call out a marking requirement, but does require the consideration of the temperature of internal and external surfaces that may be exposed to the flammable atmosphere.
