My understanding is that if you remove the heater(s) from a standard 3-pole thermal overload relay, the aux contact on the overload relay should open.
Today we came across a couple at a site where the OL contact remained closed with the heaters removed. We disconnected leads to ensure our continuity measurements were not through the starter coil or other circuit devices.
Is this normal?
Is this normal?
