aarifisher
If a motor has a service factor of more then 1.15 but has a temperature above 40c,
What do I choose 1525% or 1.15%. ???
Its per the overload mfg instructions. And what motor temp are are referring to? Ambinent air? Winding temp?
One very good solution is to use ambient compenstated overloads, such as the IEC type.
There is only one thing on that nameplate you need to be looking at for sizing the overload. (FLA). Never consider SF for the overload setting. Running in the SF can and will shorten the life of the motor.
I'm talking about Ambient temp, and about the code not mfg instructions.
