puckman
- ridgewood, n.j.
If a motor is operating at 50% or less is causing poor power factor should getting motors sized to operate at near to full load as possible be a way to go to correct low power factor ?
Should a load survey of motors be conducted to check pf ?
The reason I am asking this is because the pf meter at the service is reading .7 never much higher.
Thanks in advance for the help.
