bhalp
- Queens, NY
120 volt 1/2hp sump pump with f.l.c. 12amps & at locked rotor 22amps. what size wire should i use? & what size circuit protection should i use?
Cord and plug, or hard wired?120 volt 1/2hp sump pump with f.l.c. 12amps & at locked rotor 22amps. what size wire should i use? & what size circuit protection should i use?
Just curious -120 volt 1/2hp sump pump with f.l.c. 12amps & at locked rotor 22amps. ...
Just curious -
Test question or motor name plate data? Reason I ask is 12A is way too high for a 120V, 1/2hp motor.
cf
