Continous and non continous equpiment is based upon?
What's the current of 10ohm on 12v battery with 90%vd ad battery
Sent from my SM-G950U using Tapatalk
Non of these make sense without context. The context may have been in previous questions, or you have left out info, but there are no simple answers to them as you have posted.Having some issues with these
what happens when slip rings short out on motor..
50:1 480/277 transformer with a 0-1 volt meter what is the reading on secondary
What is equivalent to an overcurrent relay
No motor is 100% efficient. If there was such a beast it would not produce any heat when in use. You always draw more energy from the source then what you get from the output shaft, the inefficiencies is typically friction and the wasted energy is given up as heat.What type of motor are they talking about using this formula. Ac or DC I say ac because DC motors do not have an efficiency![]()
As mentioned DC motors do not have power factor, which may be your confusion here. Power factor is not so much a direct inefficiency in AC motors, but does contribute to their overall inefficiency as it does result in more losses in the supply circuit to the motor.
Most of your questions are lacking details to give good answers for them.
