4-20mA
an analog man in a digital world
- Charleston SC
- Process Control, Instrumentation & Electrical
We have a tank that we suck in a power through a vacuum powder charge system. The vac consumes volatile vapors during this time, so we now have a vac pump that has a purge on it. We want to air purge for the vac for 15 min while running after the charge. We came up with a way to do it with an On/Off switch that when turned off triggers a timer relay to purge(and run) for the set amount of time. Bench tests looks like this will work, but one of my concerns are the motor when quickly switched from "run" to "off- but after the alloted time. Is there major issues with on-off-on'ing a motor that quicky? Anyone have a better idea or route? This is all done locally in the field, no plc or dcs control.
