R Riyad Member Apr 24, 2007 #1 Hi all, What is meant by the motor relay was tested at 1.0 p.u. of FLA? and what is greater 5.5 p.u. or 1.0 p.u? Thanks
kingpb Senior Member Location SE USA as far as you can go Occupation Engineer, Registered Apr 24, 2007 #2 A simple example should help: View attachment 434 So, in your case, they are saying the relay was tested at 100% of the motor FLA. To answer your question, 5.5 pu would then be 550% of rated motor current. For more in depth knowledge, any good power system analysis book should discuss per unit.
