If the service factor for this unit is 1.15 you are just below the maximum. Running a motor using the service factor will accelerate the rate at which the insulation will age by a significant amount. Thats not to say that the unit will fail rather quickly ,just that it will fail faster than if it were below those levels. One question would be is what is the type of laod on this and is it continous?Does the motor cycle and therfore have the time it needs to cool? As long as you dont let the smoke out of the case you are good to go lol.. Joe
