This pertans to DC motors. You did not specify AC or DC in your first post. Which are you referring to?Power is proportional to speed by P = rotational speed x T.
Where power is V*I. If the current increases wouldn't that include the speed? Clarification??
If the motor current increases that would most likely be because of either a fault or an increase in mechanical load on the shaft. Increaing the load generally slows the motor down (unless it is part of a servo system).So what your saying is the increase in current has no affect on the motor???
In a series wound DC motor the field and armature are connected in series so if you lost the field you would get not current and the motor would stop. On the other hand, if you lost the load, the motor could overspeed. The only applications where I have come across series motors are traction and starter motors for vehicles.What about DC motors? It's been a while since I have had to deal with one, but if I remember correctly, I believe it was a shunt, or a series winding motor could over speed if the field was lost, I think. It's been a long time since I had any DC motor theory. Someone that does a lot of industrial could probally answer this.
In my experience, shunt wound DC motors are more common in industry than series. Lose the field on those and yes, it can seriously overspeed to the point of throwing off the armature windings. Very messy that is.
It'll do that too if you stall it for any length of time. The current continuously goes through the same com segments and they are generally not made for that.We used to call that "slinging the solder" out of a DC motor.:smile:
steve
