pipelinetech
- Las Vegas
Hi guys,
I searched through the forums and could not find anyone else who has asked this question.
I have a disconnect on a pump that houses a 240v breaker and 2 Allen-Bradley C23-D10 starters to control 2 separate pumps. There are 2 HOA switches on the front of the disconnect that control the 2 different 120v contactors. I had an extra conductor in the cable that was installed, so I landed the extra on a neutral bar in our electrical room.
In the disconnect, there is a fused terminal block that needed 120v to run the HOA switches and the starters. I came off the load side of one of the legs of the 240v breaker to power it.
When I switch the HOA switch to the "hand" position, the contactor on the starter hammers- it will rapidly move the electromagnet in-out-in-out until finally sticking in after a few seconds. It releases just fine when the 120v is taken away.
I am at my wits end on what could be causing this: does anyone here have any insight or encountered anything similar?
Thanks!
Thanks!
