Re: Motor Starters
Every motor is required to have a controller, overload protection and a disconnecting means. Controller is the correct term as used in Art 430, a starter is typically a controller. Generally when you get above a certain amperage then a controller is used, the amperage depends on the voltage, but at 120/240 probably above 2 hp. It really depends on how you are controlling the motor.
