Have a motor (not original)on a climate control compressor set-up, that is cycling way more than it probably should. Right now going to assume it is excessive air leaks throughout building, i.e. system was sized correctly.
This problem came to attention when the circuit breaker for electric motor was found tripped. Is it the thermal portion of the c.b. "tripping" because it to does not have time to cool off from the inrush currents?
I ask because I don't think the windings have shorted or ground out yet, seeing how the c.b. reset and the motor runs.
