Hello,
Looking for some advice, I am terminating many large motors that have or are prone to a large amount of vibration. Currently what I plan to use are One hole lugs crimped on with a hydraulic crimper bolted together and then covered with a T&B rubber boot. (PT# MSC250 / MSC500 FYI) I would also like to have some added protection on the wires where they enter the peckerhead, and around the T&B boots. I would like to use a rubber sheet that is very pliable so I can wrap around the conductors where they leave the LT flex and enter the peckerhead, then zip tie into place. Also would like to do the same in addition to the T&B boots so that the boots to not vibrate/rub aginst the termination Housing. The problem I am having is finding a rubber that is NON-conductive or has some kind of electrical rating. I do not want to use the rubber matting that is typically used to lay on the floor in front of gear or switchboards. The style we have used seems to be to rigid for this. Along the same lines I do not like Mastic in this application since over time it seems to get sticky and messy. Have any of you used any type of rubber sheeting that would work well in this application??
Thanks.
Thanks.
