I'm trying to figure out exactly how a motor protection relay defines motor thermal capacity and how rtd's in a motor play a role in determining this thermal capacity.  We have a multilin 269 relay which will occassionly give us a thermal capacity alarm when the motor is operated near its FLA.  I belive the relay is set up to alarm when motor is above 90% thermal capacity.
My question is, how thermal capacity in a motor is defined with a relay. Is thermal capacity strictly a function of the protection curve set up in the relay? Do RTD's add to the thermal capacity when they detect extra heat in the motor? Do they add to the capacity when the motor is operating both above and below FLA?
I was always understanding that thermal capacity was determined by what percent the motor current was operating below the relay overload curve. So if the motor was operating at 90% of FLA then the thermal capacity would roughly be around 90%? If the motor had additional heating for some reason the rtd's would add to this 90%?
