Hi
I am faced by bit of a problem. I am doing a project where the voltage available to me is 415V AC. There are a few motors that need to be installed. The pump motors have a voltage range from 380-415V so i guess they are ok. But some motors i ordered are being provided assuming a 400V supply. The biggest of them is a 15kW 3~ Motor. There is no VSD requirement. I know that the motor would run with the 400 V supply but what i don't know is will this affect the performance of the motor (it will be in operation 24/7). I have checked, the torque and maximum power is not an issue but as the supplied voltage is greater what effect will it have on the coils and is there any chance of damage.
I don't know the service Factor of the motor; do i need that to answer this question??
Also what will be the effect if the situation was completely opposite that is running a 415 V motor on 380 V?? It will draw more current but what limit of low voltage is allowable for operation?
Actually my field is instrumentation; so i don't have much knowledge about motors. Any help would be appreciated.
