Motor voltage
JdoubleU
I noticed a motor with a voltage reading of 230volts, 3phase. It is fed with 208volt, 3phase. Is this an acceptable voltage deviation.
From Baldor Electric:
"Rated voltage ? Motors are designed to yield optimal performance when operating at a specific voltage level, or a combination of voltage levels in the case of dual-voltage or tri-voltage motors. This value is known as the nameplate voltage. In recognition of the fact that voltage changes on your power distribution system occur due to changing load conditions within your facility and on the utility supply that feeds your facility, motors are designed with a 10% tolerance for voltage above and below the rated nameplate value. Thus, a motor with a rated nameplate voltage of 460V should be expected to operate successfully between 414V and 506V."
