How susceptible are fluorescent lights (120V) to voltage dip caused by motor starting (such as compressors in a 40-ton HVAC unit)? Should I avoid circuiting those two loads from the same panel at all cost? If I segregate the loads into different panels, they'll still be fed from the same distribution panel.
