sceepe
When determining the available short circuit current at a point in a distribution system, do you apply the contribution of your motors to all points in the system or just the points on the same distribution path as the point you are calculating.
In other words would the motors fed from one sub panel source current to fault on a different sub panel?
Before you point me to Bussman's EPR, it's not in there?
Lastly, it would seem to me that the short circuit current sourced from a motor would decrease the farther you get from the motor (just as it does the farther you get from the POCO xfmr). This would make the point to point method a lot more difficult because you have to start at both ends and work in both directions.
