Gaspipeliner
New member
- Ridgeland, MS, USA
I have two airdyne air compressors on a lead ane lag system however, when the second air compressor turns on it kills the incoming power breaker. Each motor is 56HP and the incoming power is on a 250 Amp breaker. I have considered that it might be to much load on the system but when I checked the load on the main breaker at most I was pulling 160 Amps. Do I need to consider a larger sevice for the Station?
