When you see a motor in a factory for a pump or something etc. and it is rated at 150HP is this input or output power? If the 150HP pump is rated for use @480V and has an FLA of 180A it would be 150KVA(approx) if the PF is approx 0.85 then does that mean the motor requires 150KVA with an output of approx,. 127.5KW or is the the input of the motor required to be 150/0.88 to equal the KVA required to run the motor?
