Google, images is really your friend here.
Using your own terms "wiring of push start stop switches for motors" gives you this result.
Images
If you go to goolge main menu, and with your own terms, in the Search line say:
books wiring+of+push+start+stop+switches+for+motors
Note that I added a plus sign between terms, this locks and qualifies in each
individual word to be searched by the search engine. Like using a quote marks, the plus sign is equal to a quote but greater, it makes the search find every part of all the terms first and then start showing results that start dropping terms form the end of list first.
will give you this
LINK
The only safe practice is to understand that some push button could be wired
in either series and parallel, and the respective wire size and type needs to be used.
Good Luck & Welcome to the Forum.
