mikekirby
- Bellingham, Washington
- Retired Inside Wireman Washington State
I'd like to mount a 24" x 18" x 6" NEMA 1 Screw Cover Enclosure between two ceiling joists, with the opening facing down, into the garage. The enclosure would be fastened to the ceiling joists through its' sides with blunt screws.
I am installing a new 200 amp residential panel in a different location in said garage. The purpose of the enclosure is to be a junction box where the original Romex cables will splice to conductors from the new panel.
The cut sheet from the manufacturer of the enclosure states 'wall' mounted.
Has anyone done something like this?
Could it pass inspection?
Alternatives?
Thanks for your help.
Alternatives?
