I drilled and tapped my round column with a 1/4" 20 tap. It won't hurt the column--
So would I, if I was a licensed electrician. But as a DIY, I should probably keep my mouth shut,:roll:This is what I would do if it were me.
Roger
Unistrut with a U-Bolt, you could make your own U-Bolt with a piece of 1/4" threaded rod.
Roger
Roger
You didn't see his comment that he didn't want to drill the beam for some reason? Hence the suggestions how to do it without drilling the beam.I don't know why you all want to make a simple job difficult. With an exposed column that unistruct, wood, U bolt, etc look like Doo Doo-- just put some threads into the beam and be done with it
I have a steel support pole in my basement that I need to mount a outlet to. I do not want to drill any holes does anyone make a bracket to secure a 4" square to a 4" round pole, a hose clamp would work just need to secure to box.
