Mounting Feeder cable conduit to fence
Solarnow
New User
California
Electrical consultant
I’m a retired General Contractor in Northern California. I am installing a solar system on my property with (3) structures, built in 1949. As such, I am upgrading main meter panel and subpage at each building. I need to run feeders to each building, currently run overhead, in a very unsafe manner. (I’m under a time constraint to complete solar by Dec. 31, 2025, or I forfeit the 30% Federal tax offset).
Existing foundations and concrete patios/retaining walls make it extremely difficult to run feeders from main service (at main house) to other (2) buildings, each about 30’ from each other.
I built a new (very strong) fence along the property line about a year ago - complete with steel posts every 8’, embedded in concrete at a depth of 3’. The balance of the fence is wood. A robust structure. I would like to use this “other structure” as the mounting surface for the conduits required.
I plan to obtain a permit for the panel upgrades, separate from the Solar permit. The building department requires that I reference a specific code section that describes installation of these conduits and feeders - and requirements for this design - to be included with my permit submittal. Meaning, the conduit housing the feeder cables, mounted to a fence structure, as an allowed/approved installation method.
Is it possible for you to comment on this, and possibly refer me to the proper NEC section that I can reference with my permit application? While I do not have access to the NEC, if you provide the specific section, I may be able to find just that portion online.
Please try diychatroom.com
This site is designed for:
  • Electrical Contractors
  • Electricians
  • Engineers
  • Inspectors
  • Instructors
  • Other electrically related individuals
This NEC® Forum is for those in the electrical and related industries. Questions of a "How-To" nature by persons not involved in the electrical industry will be removed without notice.
Knowledge and the practical application of the National Electrical Code is an essential part of all electrical installations. If it's important for you to understand the National Electrical Code, then look no further.
To better help us serve you, please be sure to update your account details with your occupation field and location if you have not done so already. You can access your account details by clicking on your account name at the top right of the page when on the forums.
