We are using passive harmonic filters which are combination of 2 reactors (line and trap) and capacitor bank (trap) in UL508A VFD enclosure. Line reactor is in series with source and VFD; trap reactor and caps are in parallel (please see below).
So A1 B1 C1 is the supply, A2 B2 C2 feed the VFD (T1 T2 T3) and AT BT CT are connected to trap circuit via conductors that are smaller than supply (about 40%). My question is: instead of running wires from AT BT CT to fuse mounting blocks, can I just mount the fuses directly on AT BT CT which are just bus bars? Can I just ask the manufacturer whether mounting the fuses on reactor bus bars violate their UL listing?
Thank you
Thank you
