VirutalElectrician
- Mpls, MN
- Sparky - Trying to be retired
I have about two dozen LED wall packs I need to mount to the side of a pole barn...Think ribbed steel if you are unfamiliar.
I've been Googling for ideas and the industry in general seems to have failed here. No one has come up with a decent solution and lots of hacked up ideas out there.
The back looks like this:
the inside:
The documentation states: "The back plate has a cast-in drill and knock-out template to match any standard recessed junction box"
Which seems to be a lie. A round pan box fits nicely in the recessed circle, but no such knock outs exist on the inside to put screws through to secure them together.
They have 1/2" threaded holes on the side and bottom for conduit, but that would be unsightly to use when the back should be more than adequare.
The 3 smaller round recesses are for 5/8 bolts. But on an uneven surface like ribbed steel, there wouldn't be a good way to seal them once you penetrate the structure as there'd 1/2 space between the wall and the fixture. Enough for water, but not enough to room to get back there and seal it up once the bolts are in place.
I found these stand off type things used for mounting solar panels to pole barns:
Which might just work, but there's still the issue of attaching a box to the back of the device. Would have been nice if they had just put another 1/2 threaded hole there instead of the mess that's there now.
I contacted Hubbell in regards to how much weight their boxes were designed to hold, they said boxes with 6/32 screws are designed to hold 6lbs. They also make some Light packs (the LNC4 series) that appear to be designed to be supported by a 2 gang outdoor box. So I asked them what box is supposed to be used to support their heavy LNC4 devices, but haven't heard back yet.
the inside:
