Designer69
hi, has anyone seen or designed a wall mounted panel that is actually mounted over existing 1.5" emt conduit?
due to space limitations, it would be easier to mount the new panel in this type of configuration rather than moving the existing conduit/supports.
also if this is acceptable, can you help with code reference supporting this?
Thank You!
Thank You!
