I was told by an inspector at my building department that I should not physically attach the SPA disconnect box (a metal rain-tight box) to the chain link metal fence post and that I should mount the disconnect box on it's own post even if it's ajacent to the fence. His reasoning was that a short could possably energize the fence with the 220 circuit.
I have seen all sorts of electrical devices both single phase and three phase mounted to the frame structure of metal buildings as well as conduits running along chain link fences so I question the logic of this since a metal fence is not all that different than a metal building.
Can anyone please cite any section of the NEC that prohibits or allows the mounting of a (SPA) disconnect to a chain link fence post? Perhaps I can get the building department to allow it. Adding a seperate post would not be astetically pleasing.
I planned to weld a couple of pieces if strut to the fence post to provide a surface to bolt the disconnect box to so a solid mount is not the issue here.
Thanks.
Thanks.
