I am doing a panel replacement job in a triplex that failed inspection because some (pre-existing) circuits in the panel control common areas and the panel in not accessible to all residents (NEC 210.25 violation). The panel is on an exterior wall so the inspector suggests moving panel to the exterior on the other side of the wall where it is accessible by all.
I want to place the outdoor surface-mount panel directly on the opposite side of the wall, and drill through both panels (and the wall) so that THHN wires can be run between the exterior panel and the existing interior panel (which will now be a junction box). Is this allowed under NEC? What type of fittings can I use to accomplish this? The wall thickness does not allow room for two terminal adapters (wall is about 1 inch).
Thanks for any help! It is greatly appreciated.
