projectstarter
New User
- Connecticut
- air traffic controller
Looking for Advice on 100A → 200A Service Upgrade + Panel Relocation
Hey everyone, ive lurked on here for a while but first post. Looking for some guidance from those with more experience in service upgrades and panel relocation.
I’ve done a fair amount of residential electrical work including panel upgrades, however I don't have experience with the outside work of panel upgrades, like weather heads, meter bases, etc.
Option A
Is Option A (moving service to garage) the best long-term and most code-compliant solution?
Any issues or things to think about with temporarily installing the new 200A panel as a subpanel besides the obvious like operate grounds and neutral bars?
Thanks in advance — appreciate any thoughts, code references, or advice before I move forward.
Current Setup
- House has 100A service
- Main panel: old Square D QO (QOBW20M100), located in a bedroom closet, has about 14 circuits
- Subpanel: 40A Murray fuse box located in the garage
- House is about 60 ft across (panel-to-panel distance)
- Existing loads: pool pump, normal household circuits, multiple window/wall ACs, air compressor.
- Future loads: potential hot tub + EV charger/chargers.
- Service drop could enter from either side of house (same distance from pole) no obstructions/height issues.
Planned Upgrade
The plan is to upgrade the service to 200A, but I’m debating the smartest way to manage the panel locations.Main Question
Which approach would you take?Option A
- Move service drop to the garage where a service entrance actually makes sense
- Install new 200A panel in the garage
- Convert the existing 100A panel in the bedroom closet into a subpanel
- Upgrade existing service location (still in closet — I believe this is not compliant with current code for panel location) and a larger physical panel would not fit.
- Make the garage panel a larger 100A or 200A subpanel
What I’ve Already Done
I decided to get some of the prep work done myself:- Purchased 100 ft of 1-1-1-3 SER Al and a 100 amp QO breaker
- Picked up a brand new Homeline 200A convertible panel value pack (Marketplace score: $90)
- My thought was to replace the 40A fuse subpanel in the garage with the new panel but keep it fed as a subpanel for now
- The existing subpanel is fed with what looks like #6 or #8 copper MC — I planned to remove and repurpose that and run the 1-1-1-3 SER in its place
Questions for the Pros
