Moving Hot Tub
kayaker
New member
Out of here
I am moving my 3 year old hot tub from my elevated wood deck, to an existing slab. Both existing wiring from present service panel to GFCI, and location of that outside GFCI panel will remain the same. From the GFCI to hot tub only will change. I am now using about 20' of Sch 40 electrical PVC under deck and then just up above deck and into side of hot tub. New hot tub location can be between 8'-10' from the GFCI panel, all across an existing concrete slab that butts up against that wall. Can I use PVC electrical conduit (perhaps Sch 80), surface mounted to slab, to feed across the concrete and into the tub? I would route it away from common foot traffic, which would be require about 15' run.
With the hot tub placed, the slab will extend out from the hot tub 2-7', depending on direction. Any bonding now required, would a commercial base cancel that requirement?
thanks
I am closing this thread, in accordance with the Forum rules. This Forum is intended to assist professional electricians, inspectors, engineers, and other members of the electrical industry in the performance of their job-related tasks. However, if you are not an electrician or an electrical contractor, then we are not permitted to help you perform your own electrical installation work.
If I have misjudged the situation, if for example this project is related to your work, then send me a Private Message. If you can show me that I am wrong, and that you are a licensed electrician (or at least a licensed apprentice), then I will reopen your post, and offer an apology for the delay and inconvenience.
A reminder to all members, if you see a questionable post, feel free to report it by clicking the
button at the bottom left corner of the post.
