Moving loads to subpanel (neutrals)
I want to move loads from my main panel to a sub-panel. The panels have bonded grounds and neutrals. (Hope I said that right.)
If I am simply moving the load breakers do I have to find the neutrals and grounds and move them? It woulds seem that since the panels are bonded to each other that neutral returns properly and there is a proper ground.
I don't think neutrals and grounds are labeled but I will check. If not labeled how can one check? Can't, I'd think, right?
Again:
1) Do I need to move the neutrals?
2) Whatever I move, if the wires won't reach do I just use wire nuts to properly sized ROMEX and run per code?
Thank you,
Mike G
I am closing this thread in accordance with the forum rules.
This site is designed for:
  • Contractors
  • Electricians
  • Engineers
  • Inspectors
  • Instructors
  • Other electrically related individuals
* This NEC� Forum is for those in the electrical and related industries. Questions of a "How-To" nature by persons not involved in the electrical industry will be removed without notice.
Roger
