I am installing 3 mr slim indoor units to be connected to the outdoor unit. I will be running my interconnects up the side of this slab two story into the attic and across attic down opposite outside wall into the rear of my three units. Specs call for three interconnect wires with ground. Do I need two break all three at a disconnect next to the inside unit? Ugly? They do not make three pole residential snap switches. Also any recommendations on the type of cable would be helpful. Each run is approx 150 feet from outdoor unit to indoor unit. Both units are 250 volt with out neutral. my outdoor unit will be fed with a 12/2 from an AC disconnect switch attached to a 200 amp panel.
