Never seen ent in hospitals. I think the rep is nuts.Contractor is installing a new MRI in the local hospital. demo of existing MRI shows equipment wiring done in smurf tube. Manufaturer rep says that this is the way it is typically done. anyone have any experience with this, thanks.
Makes sense - stainless steel is approximately non-magnetic, as long as you've got the right stainless steel.I have done a couple and they all specked stainless steel fasteners, screws, and gutters
Just make sure that you dont have any iron or steel in your construction inside the MRI magnet's exclusion zone, the details of which will be in the MTI installation instructions, and may well be painted or signposted by the time you get there.
I can understand why smurf tube is used; its non-ferrous, and the copper wire inside is also non-ferrous, so no nasty magnetic accidents waiting to happen.
Have a google for what MRI magnets can grab; they are hellishly strong; theres a well reported fatality due to a patient being struck by a flying oxygen cylinder that got inside the exclusion zone...
Thats the bottom line here; anything metal is going to be tugged at - hard - through its working life. When the magnet gets quenched metallic stuff is going to be released too. As long whatever is installed is up to those forces and will stay where its put, then all is well with the world.That's all true, but it is also true that it is common to have EMT conduit and other metal items inside the room as long as they are securely fastened.
