jamieschmidt
Multiconductor cables with a gas/vapor-tight continuous sheath are required to be sealed by removing the outer jacket and any other coverings so that the sealing compound will surround the individual insulated conductor and outer jacket, minimizing the gases and vapors that are passed.
An exception to 501.15(D)(2) and 501.15(E)(1) Exception No. 2, permits shielded cables and twisted pair cables to be treated like a single conductor so that it is not necessary to separate the individual conductors of the twisted pair, or remove a shield.
Is it ok to not remove the outer jacket of the shielded cables and twisted pair cables when sealing them in a Class I area? My concern is that removing the outer jacket has the potential for damaging the shielding of the cables and that this may cause more problems than minimize gases.
