Hello all,
The more I re-read the section of 501.15, the more confusing it becomes. Any help here to clear up the requirements is greatly appreciated.
If we have a motor starter that is in an unclassified location that controls a motor in a Class 1 Div 2 area via a MC-HL multiconductor cable, does it require a seal fitting on the cable at the motor lead box, the starter enclosure (i.e. outside rack mounted type), or both? Control cable is similar and are separate from the power cable to a start/stop in the same location.
Would TMC, or TMCX, terminations at both ends be code compliant? This cable is a direct burial application that stubs up to the motor.
Thanks for your advice, great forum.
