Rockchalk08
- WillsPoint Tx
So here is a question that I cant seem to get a clear answer on. It might be the way I am interpreting the code book (NEC 2017). Is it ok to pull two multi conductor cable (3C with Ground), where one all conductor of the first cable used for all three phase and ground and only one conductor of second cable is used for Neutral and rest of the conductor of second cable is SPARE. Both the cables are in the same Raceway (Tray and Conduit).
