sparks27
- Portland, Oregon
I'm working at a senior community. I have questions about the grounding of the panels for the individual units. The buildings are built in (1960) sylvania services. ok, 400a 1ph. 120/208 service. Six disconnects at meter section. Cold water ground and ground rod at service, bonded together. Then 100 amp sylvania 2 pole main breaker. 2- feeders plus nuetral( no ground wire), in 1-1/2 emt thru attic to apt.sub panel. The neutral goes to neutral bar. all wiring in apt. is steel flex. no ground wire. sound ok?
