rowelelectrical
Inactive, Email Never Verified
HI,
Im doing a load calculation for a unit in a multifamily dwelling building. My question is, if i use the calculation method on 280.82 which is the first 10KVa and 40% remainder on loads for calculating the units main service, and when i have the total loads for each unit using this method of calculation, is it still right to use table 220.84 for calculating the building's service knowing i have used the 10KVA and 40% remainder on calculating the service for each unit? the building has 15 units so I have to use 40%.
Appreciate all you advise.
Thanks,
Thanks,
