assuming a (24) dwelling unit multi family building. each dwelling unit has a connected load of about 40kw (using round numbers). after applying demand factors, the calculated load is about 20kw (again using round numbers). do I use the connected load of 40kw or the calculated load of 20kw per dwelling unit to calculate the total feeder or service load. and then can I apply the demand factor shown in table 220.84.
Thanks, mike h.
Thanks, mike h.
